Re: Using The TI PCM4222 A/D Evaluation Module
Posted: Wed Dec 13, 2017 2:41 pm
hi
I notice c64 (unpopulated) has a nice large pad, just happens to connect to Vocm!
and the 2.7nf that I think you mention is ' c61 ' right up close to the PCM4222 so that is out of the way and post any potential modification.
I could scratch the traces (if the traces are only on the top layer) after r3 r4 and insert a signal relay (pic attached), to switch between the :
relay state 1= Figure 52. external home made, Noninverting Differential Input buffer ( I may use OPA1611's if I remember they are quieter than suggested) and have it mounted as close as possible to the EVM.
relay state 2 = The already on board Differential Input Buffer.
by switching/toggling between the two, that would stop any additional noise from which ever is not in use, perhaps if the relay is shielded well also.
I may just enjoy the EVM using 150uf cap's before I do this; but this might be a way to go?
thanks for the inspiration.
The diagram shows c61 (2.7nf) is pre to the Test points but it is not. it is very close to the PCM4222
