Parts and PC Boards Available at Etsy RockmoreLabs
Locked
Post by mediatechnology » Thu Mar 12, 2015 5:34 pm
We've got the stuff you need from hard-to-find vintage parts, THAT and JRC audio ICs, PC boards for projects and more.
International shipping available, Visa, Mastercard, American Express and other credit cards are accepted at the Rockmore-Labs Etsy store: https://www.etsy.com/shop/RockmoreLabs? ... p_redirect
Bare Unassembled PC Boards for Mastering:
MS Mid/Side PC Board https://www.etsy.com/listing/239662236/ ... de-encoder
Stereo Width Controller: https://www.etsy.com/listing/239562211/ ... -for-audio
Insert Switcher: https://www.etsy.com/listing/275593012/ ... tering-two
Flat Moving Magnet Phono Preamplifier: https://www.etsy.com/listing/242456738/ ... mp-for-raw
Phono RIAA EQ/Monitor Switcher: https://www.etsy.com/listing/254169432/ ... -for-phono
Bare Unassembled PC Boards with IC Kits
MS Mid/Side PC Board plus ICs: https://www.etsy.com/listing/259251317/ ... de-encoder
Stereo Width Controller PC Board plus ICs: https://www.etsy.com/listing/223479364/ ... -for-audio
Phono Transfer System Flat Preamp, RIAA EQ/Monitor PC Boards plus ICs: https://www.etsy.com/listing/271467128/ ... d-set-with
Assembled and Tested PC Boards for Mastering:
MS Mid/Side Matrix Assembled and Tested: https://www.etsy.com/listing/220443277/ ... de-encoder
Stereo Width Controller Assembled and Tested: https://www.etsy.com/listing/213139462/ ... -assembled
Insert Switcher with Flip Assembled and Tested: https://www.etsy.com/listing/289105177/ ... tering-two
Flat Moving Magnet Phono Preamplifier Assembled and Tested: https://www.etsy.com/listing/271460128/ ... m-balanced
Phono Transfer System: https://www.etsy.com/listing/271462244/ ... -mm-preamp
Dual Op Amps:
NJM2043DD: https://www.etsy.com/listing/271305007/ ... e-audio-op
NJM2068DD: https://www.etsy.com/listing/251746388/ ... oise-audio
NJM2114D: https://www.etsy.com/listing/237280294/ ... p-improved
NJM4556AD: https://www.etsy.com/listing/237169465/ ... gh-current
NJM4560DD: https://www.etsy.com/listing/271304737/ ... dio-op-amp
NJM5532D: https://www.etsy.com/listing/251749876/ ... dual-audio
Single Op Amps:
NJM5534DD: https://www.etsy.com/listing/251749412/ ... e-audio-op
THAT Corporation Audio ICs:
THAT300P14 https://www.etsy.com/listing/237206267/ ... -4-npn-dip
THAT320P14 https://www.etsy.com/listing/237316698/ ... -4-pnp-dip
THAT340P14 https://www.etsy.com/listing/237174061/ ... ay-2-npn-2
THAT1200P08
THAT1206P08 https://www.etsy.com/listing/237209797/ ... anced-line
THAT1240P08 https://www.etsy.com/listing/237317894/ ... ceiver-dip
THAT1246P08 https://www.etsy.com/listing/237317358/ ... ceiver-dip
THAT1510P08 https://www.etsy.com/listing/237281054/ ... ier-ic-dip
THAT1512P08 https://www.etsy.com/listing/237205735/ ... ier-ic-dip
THAT1646P08 https://www.etsy.com/listing/237281476/ ... ine-driver
THAT2180BL https://www.etsy.com/listing/237282074/ ... controlled
THAT2252L https://www.etsy.com/listing/237187109/ ... tor-lot-of
THAT4301P https://www.etsy.com/listing/237285168/ ... in-dip-lot
Miscellaneous Semiconductors:
TL783CKC https://www.etsy.com/listing/289103203/ ... lator-125v
VTL5C3 Vactrol https://www.etsy.com/listing/271464714/ ... tor-perkin
ZTX851 NPN "Low Noise, Low rbb" Transistor https://www.etsy.com/listing/289105805/ ... transistor
ZTX951 PNP "Low Noise, Low rbb" Transistor https://www.etsy.com/listing/275591844/ ... transistor
Power Supplies:
Meanwell P25A14E-R1B +/-15V, 5V https://www.etsy.com/listing/222444193/ ... ple-output
"We have grown to love our captors and demonize those that try to lead us to freedom."
Locked
Who is online
Users browsing this forum: No registered users and 0 guests
