The second one can be used with either a balanced or unbalanced filter. It's a little more refined using balanced I/O and the precision inverter but does indeed use both halves.Thank You for the confirmation, I just finish read and learn Your explanation slowly and carefully, so the difference between 2 version that You create: the last one is using balance filter and the the first one is unbalanced filter right?
If you switch resistors in the first example you will want to always have the largest value in circuit and then use a switch to parallel the values to raise the frequency. The reason for that is that they provide the bias current for the op amp. In addition the overall filter input needs to see a DC path to ground: The previous stage provides that.
I do understand why you would want an EE in the monitor path.
The choice of op amps is pretty flexible.
