Maybe you should consider using J2 and modifying the range from +3, 0 -3 to something else. (+4, 0 -4?)
It should be relatively click-less that way.
Post by billshurv »
That was plan B when I realised plan A was stupid (switching gain on MC board) and If you switch in a parallel resistance that gives you what you need. I'm just having a risk averse moment as, come next year I will need a visa to go and fix it! He is known to change cartridges 2 or 3 times an evening.
I don;t like throwing away gain but sometime you have to be pragmatic.
Your client is off the island and on the continent?
Post by billshurv »
Not so much a client as a friend. I figured having someone to encourage me would accelerate the completion of my set as well*. He's paying for the parts and labour will be bartered for some spare cartridges he has.
*At least that was the theory. Life has a way of getting in the way :)
Post by billshurv »
No Progress in last few weeks due to other comittments, but my PCM4222 EVM has arrived so I can integrate that. As well as giving me galvanic isolation it will allow me to offend all those sensitive souls who think digitising a vinyl signal will rob it of some magic. Happy days :)
Post by billshurv »
Wife away with kids for a couple of days so time to crack on. And first dumb question. How did you intend the shield drive to be setup for remote switching of gain? I'll just be switching between A&B on the first build.
brianroth
Post by brianroth »
I have a potential idea to use the line level portion of the system for an unusual application.
Background. Several years ago, Chad Kassem (owner of Acoustic Sounds here in Salina, KS) bought the Neumann lathes and all of the related custom electronics from the estate of Doug Sax along with the Mastering Lab "brand". Everything was shipped from CA to KS, and a variety of outside experts have been bringing it back online. I initially knew nearly zero about cutting lacquers, and am still a mere babe in the woods. But, I'm the guy who chases down problems within the barely documented custom electronic systems, which are largely vacuum tube based.
There is one feature that Sax never implemented, but more than a few of the various guys through here say is important to have.... the ability to monitor the RIAA equalized signal that drives the cutting head. That is the very last point before the stylus cuts the groove. The lacquer cutting guys call that "feedback monitoring", which was initially confusing to me since there is also a feedback signal going from the cutting head back to the amplifier. It's just a matter of jargon that I'm learning!
In this case, the custom cutting amplifier is all tube (with a very handsome Peerless output xfmr on each channel). Each channel uses a pair of 6550's which should produce around 100 Watts into an 8 Ohm load. I seem to recall someone telling me the Neumann cutting head provides a 6 Ohm load, but whatever.
In addition to the connector which feeds wiring to the cutting head there are two unbalanced (TS) 1/4" phone jacks paralleled across the Peeerless xfmr secondaries. That seems to be the ideal place to "sample" the RIAA equalized signal. Those jacks are currently unused.
Back of the napkin calculations tell me that the maximum voltage will be in the vicinity of 25-28 VRMS.
Rather that wiring a 10000000 dB (lol) pad between those phone jacks and the input of a typical phono preamp, my thought is to construct a minimally populated version of Wayne's line level RIAA board. I know a small-ish pad will be required to tame the signal down a bit before feeding into the card. I like the available trimmer pots on the card which will allow level matching for A/B comparisons between amplifier in and out.
Just musing on this possible solution. Perhaps Paul may also have some comments.
Thanks!
Bri
www.BrianRoth.com
I am not the mastering guy around here (although my dad was a recording engineer back in the 50s and probably did some).
I do know a little about RIAA playback EQ... it is basically a low pass filter with gain incorporating rolloff poles at 3180usec and 75 usec, with a zero thrown in at 318 usec. If you use google you can probably find a passive RIAA network schemo.... I vaguely recall at least one would be esoteric phono preamp back in the day using flat gain stages around a completely passive RIAA EQ. Since you don't need the gain stages you might just use the passive RIAA EQ portion by itself.
My last phono preamp (to end all preamps) decades ago, used a flat open loop front end gain stage feeding the 75 usec roll off LPF, followed by an active gain stage with the rest of the RIAA EQ. My preamp before that one (I designed a lot of preamps) had a flat front end gain stage (30dB?) followed by active RIAA EQ (again with more gain).
Good luck I hear vinyl is coming back... :lol:
brianroth
Post by brianroth »
It looks to me that Wayne has a "paint by number" kit which should simplify the work required to set up that monitoring path.
Bri
www.BrianRoth.com
OK never mind....
