"Composite Op Amp For High Performance," Siliconix AN81-3, July 1983
Re: "Composite Op Amp For High Performance," Siliconix AN81-3, July 1983
Post by JR. » Sat May 18, 2019 12:05 pm
IIRC Brad Wood (RIP) was working on a crazy low noise JFET MC preamp as one of his later projects.
He may have left some evidence around the internets, I don't see much on his old facebook page where I think he may have shared it once.
Post by mediatechnology » Sat May 18, 2019 1:10 pm
Brad gets the credit for introducing me to the ZTX851.
At the time he hadn't used it but had read the new edition of Horowitz and Hill and pointed me in that direction.
Post by billshurv » Sat May 18, 2019 3:17 pm
Found it. This is the list from Gerhard posted on DIYAudio. The CPH5902 is the one that looks most interesting even if you have to ignore the built in bipolar. Of course linear might finally pull their fingers out and sort out production of the LSK489...
Post by mediatechnology » Sun May 19, 2019 5:50 am
The CPH5902 is one they got from Sanyo's product line. Interesting. Thanks for the list.
https://www.onsemi.com/PowerSolutions/p ... id=CPH5902
This is the parametric table of ON JFETS. ON has nice tables.
https://www.onsemi.com/PowerSolutions/p ... 6/products
Post by mediatechnology » Sat Oct 12, 2019 11:00 am
Looks like Amber took Siliconix advice and used this in the 3501 front-end:
Amber 3501 Front End Using the Siliconix Composite Op Amp Topology.
Note that the 5543's inputs are grounded and the compensation terminals are used for the FET front-end.
Amber 3501 front-end pdf: https://proaudiodesignforum.com/images/ ... _Input.pdf
Post by JR. » Sun Oct 13, 2019 11:18 am
Nice for decades ago...
I was always apprehensive about the 553x compensation scheme while it was fine when used sensibly. I didn't like any open loop wiggles in or near the audio passband.
FET front end with 600 ohm drive capability now off the shelf.
{edit] another hybrid approach I considered way back when was using a decent front end mixed with a LM359? an old Norton amp similar to the popular lm3900 but much better /edit]
Post by mediatechnology » Sun Oct 13, 2019 9:31 pm
None currently available are probably good enough for a distortion analyser front-end without some external bootstrapping to reduce CM distortion.
Post by JR. » Mon Oct 14, 2019 10:21 am
I'll take your word for that. My experience with designing relatively modest performance test gear (TS-1) was much harder than it appears, albeit using that eras technology.
