"MS Mini" Basic Mid Side Board
Update September 9, 2021. The construction thread is located here: The construction thread for the Mid Side Mini is located here: viewtopic.php?f=7&t=1272
I've had a basic MS board on my list to replace the original I did over a dozen years ago.
The "MS Mini" incorporates the Mid Side gain offset capability of the MSII.
Using jumpers, Mid Encode level can be attenuated 6 dB [(L+R)/2] and an offset gain of +6 dB applied on decode to maintain MS ratio.
Using a jumper and an IC change (IC6 1240 or 1246) Side Encode level can be boosted 6 dB with a decode offset of -6dB.
Gain offsets in the Mid, Side or both Insert Sends present more-balanced levels to outboard gear.
Side is particularly level-challenged often being 10-20 dB below Mid.
The MS-Mini's decoder, identical to the MSII also prevents M+S and M-S from producing 2L and 2R.
This avoids having to incorporate a -6dB stage to maintain unity gain.
MS-Mini PC Layout
The board is about 3.7" by 2.75".
I'll be ordering them in the next day or so and should have a small run in about 10 days.
Re: "MS Mini" Basic Mid Side Board
This is the schematic for the "Mid Side MIni."
Mid Side MIni Compact MS Encoder/Decoder
Nice
Post by Gold »
I still have a pile of the V1 PCB's that I get good use out of. This is a nice addition to the line.
Thanks guys!
I'm expecting a small run of boards to arrive in the next hour or so.
Just in...
Let's see if it runs.
Mid Side Mini PC Board
Works great!
MS Mini PCB Assembled
Left > Right Crosstalk Full Encode/Decode
MS Mini Crosstalk L Into R
The full encode/decode 20 kHz unweighted noise level is about -96 dBu.
The dynamic range is 123 dB with +/-15V supplies.
MS Mini Noise Level 20kHz BW Full Encode Decode
