Relays for Projects
Relays for Projects
Omron's deliveries for DPDT relays have stretched out after Panasonic left the market for the DS2Y-series and globalist-engineered supply chain disruptions began.
The project BOMs show Omron but there are several options.
Here is a Mouser Project Manager list of 12 and 24V DPDT relays.
I recommend those rated for low signal currents and those that have high-sensitivity coils.
https://www.mouser.com/ProjectManager/P ... e473282442
At the moment 24V relays seem to be the ones on back-order.
The Insert Switcher and RIAA-EQ boards use 12V.
Most others use 24V.
