DIN Connector Contact Arrangements
I recently had the need for 5 pin 240° DIN receptacles - an oddball configuration - and located this chart.
It might help others with their oddball DIN connectors.
DIN Connector Contact Arrangements and Mechanical Drawings: https://proaudiodesignforum.com/images/ ... ements.pdf
Re: DIN Connector Contact Arrangements
Found this document which shows DIN connector pin numbers:
Note that the 5 pin 180° and 240° have different order.
